Re: Can I PC this head?
i did the jugs and heads on my harley with eastwoods hi-temp silver. the key is to clean clean clean. eastwood sells a spray called pre prep. I sprayed mine really good then baked for about an hour and repeated a couple of times. this makes sure all the contaminates are out of the metal. it came out perfect and with the high temp powder I dont worry about heat. The only reason I went wish eastwood instead of caswell powder is because they had the hi-temp color i needed
