Re: Anno in the basement?
It should work as long as the surface holding the magnet is smooth enough. If the magnet keeps getting stuck because the bottom of your tank isn't smooth you could try putting a piece of plexiglass or something under the magnet.
EDIT - would it be possible to cut out a hole in the table the exact size of the stirrer so that you eliminate the gap?
