Old 09-16-2008, 10:29 PM
stevepelle91 stevepelle91 is offline
stevepelle91 is on a distinguished road
Default Re: Im lost, can someone help me get started up?
When constructing your tank you should stay away from most metals in direct contact with the acid, unless using it as a cathode or anode. Plastic bins & totes are usually fine, you want to stay away from polyurethane though.
Here is a huge list of different chemicals and materials that are resistant to certain things:
http://www.lgpc.com/MagDrive/CRC.pdf
As for the acid, buy it at NAPA auto parts. It comes pre-dilluted as "Battery Acid", about 33% sulfuric acid. You should mix the NAPA battery acid in a 1:3 ratio to water, so 25% being battery acid & 75% being water. So in the end, the potency of your acid bath will be about 10% acid.
So simply mix 3 gallons of water per 1 gallon of NAPA battery acid.
Also, make sure you use distilled or reverse osmosis water for everything.
The rest of the chemicals you will need will be from Caswell and the ratios are listed on the product.
