Originally Posted by spills
thanks man, that cleared up a good bit! Im wondering if some tuperware from walmart would suffice, the bigger ones about 16"x6"x6". I could get those relatively cheap, and they come with lids as well. I doubt they're made of polyurethane either
Bigger is better... you need room betwen the parts and the cathode, and between each part.
Heat is built up. A bigger tank will disapate the heat better.
