Originally Posted by acidrain
Bigger is better... you need room betwen the parts and the cathode, and between each part.
Heat is built up. A bigger tank will disapate the heat better.
Yup and acid is cheap, if i were you i would grab a 20-30 gallon tank. Should cost you about $40 to buy the tank from Walmart and fill it up with the acid/water.
