I am going to purchase a gallon (which will make 32 gallons) of the Iron Phosphate Primer. The thing I was needing to know is, Will the ceramic boiling heaters
http://www.caswellplating.com/suppli...c_heaters.html work for this solution since it will be a 30 gallon tank?
or will the ceramic plating heaters be better?
http://www.caswellplating.com/supplies/heaters.html
I know the boiling heater is made to bring the solution temp to a boil which is defanetly to hot for the phosphate and that the plating heater is preset at 110 degrees. Phosphate range 70-160degrees. But I didn't know if I would need the larger one since it is 30 gallons. Thanks
