Old 11-17-2003, 05:53 AM
drfjr1976 drfjr1976 is offline
drfjr1976
OK got a nother "?" for you. How does the Phosphate leave the finish? Does it change the apperance in any way, color or texture? The reason I am asking is because i do a lot for aluminum parts that I polish certain areas of and I do this before coating.
If the phosphate will affect the polished areas, will the High temp tape keep the phosphate off. Or will it remove the tape since it is a detergent so to speak.
And if the tape will protect the areas, will it need to be removed and fresh tape applied before coating.
Thanks again
