Old 11-18-2003, 08:44 AM
non-stick non-stick is offline
non-stick
You just answered your own question,bud. Denatured or MEK is the way to go. Anything left after blasting will just be light surface oils from handling and blasting smut. I suggest getting a container and a paint brush, setting one end in the container and "brushing" the solvent on starting at the top and working all the way down until you have sufficiently "rinsed" the part and hit all surfaces. After that.... blow off with compressed air and that is more than enough clean to powder coat over. Keep it simple and quick, ya know? Hope that helps.... Russ
