jagrc,
When sealing with water don't drop it into the boiling water at first. Placing the part straight into boiling water will make most all of the dye leach out of the pores before it is sealed. Hang the part in the steam for 30 minutes or so first. I only place my parts in the water for 10 minutes or so at the end of the process. Not boiling but after I have turned off the burner. Try it, it will work.
Later,
Tim
