Thread: insulation
Old 01-04-2009, 03:41 PM
mxdad423 mxdad423 is offline
mxdad423 is on a distinguished road
Default Re: insulation
There may be some that disagree with me on this but I build my oven and used R-30 pink insulation and it works great, gets to 450 degrees in 4 to 5 mins and holds the temp great. I called owens corning before I made the decision to use it and the R-30 pink insulation is good up to 1200 degrees. Just make sure you get the unfaced, can't use the faced the paper wont take the heat, but as long as you go with the unfaced it works great. Hope that helps you out.
Kevin Smitley
