Old 01-04-2009, 11:34 PM
acidrain's Avatar
acidrain acidrain is offline
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: Splash masking questions
Add 1 step... after washing with bleach (full strength laundry bleach) and rinsing, wash again in 1:3 battery acid/water mix, and then rinse thoroughly.
Yes, allow the surface to dry before applying the rubber cement.
Seal normally, THEN remove the rubber cement with laquer thinner, or better yet, toulene.
You can reduce the rubber cement a bit if you want with toulene... not many other solvents will reduce it.
After you remove the rubber cement, seal some more just to make sure.
I do things.
