Old 01-05-2009, 10:33 PM
acidrain's Avatar
acidrain acidrain is offline
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: Help... wont take dye
Probably lost connection. Are the racking wires aluminum? Did they take dye? What did the volts do during the run?
It looks like your math is correct, although the ano bath temp is a little low (68-70F is ideal), it shouldn't make the pores so small that dye won't penetrate.
I do things.
