Old 01-05-2009, 11:09 PM
xgenmods xgenmods is offline
xgenmods is on a distinguished road
Send a message via AIM to xgenmods
Default Re: Help... wont take dye
Originally Posted by acidrain View Post
Probably lost connection. Are the racking wires aluminum? Did they take dye? What did the volts do during the run?
It looks like your math is correct, although the ano bath temp is a little low (68-70F is ideal), it shouldn't make the pores so small that dye won't penetrate.
Racking wires didn't take dye well ether. Current was achieved as needed at around 19 volts. Yes this is with aluminum wires that are threaded into 1/4 20 holes about a half inch deep. I don't think they lost connection. Am I able to use stainless screws with a stainless nut to fasten the aluminum wire via tightening it in the holes? The other problem I seem to be having is that all my bead blasted parts are turning grey.
