Old 01-06-2009, 12:20 AM
acidrain's Avatar
acidrain acidrain is offline
acidrain has a spectacular aura aboutacidrain has a spectacular aura about
Default Re: Help... wont take dye
Beadblasted parts turning gray could mean contamination, but most likely you're over-blasting... just a quick back and forth pattern at 60psi is what I do.
Your volts seem normal considering the cool bath.
Was the dye heated to 140F? Are you able to check the PH?
I do things.
