  #9 (permalink)
Old 01-06-2009, 01:36 AM
xgenmods xgenmods is offline
xgenmods is on a distinguished road
Send a message via AIM to xgenmods
Default Re: Help... wont take dye
Originally Posted by acidrain View Post
Beadblasted parts turning gray could mean contamination, but most likely you're over-blasting... just a quick back and forth pattern at 60psi is what I do.
Your volts seem normal considering the cool bath.
Was the dye heated to 140F? Are you able to check the PH?
Yeah that could be a good chance. I did however lye dipped them and desmutted them. Beads are new so not sure if contamination on the media would be a factor or not. How exactly do you check the ph of dye? Should it be around neutral?
