Old 01-06-2009, 09:21 PM
ed_denu ed_denu is offline
ed_denu will become famous soon enoughed_denu will become famous soon enough
Default Re: 3 2000W in a 4x4x6?
Originally Posted by newchapter View Post
OK.. I can get 2 more of elements like that for only 10 bucks a piece. would that be to much wiring?
I would use hi temp wire running into the oven to the elements. Something like the MG wire McMaster Carr sells. Once the wiring is outside the oven, then 'normal' stranded wire will work fine and is relatively inexpensive. It just needs to be sized based on the current draw of the elements.
As Ted pointed out you do need to get to 10K watts minimum.
