Re: Splash masking questions
I read about your problems earlier.What I dont understand is how you can run a part for 25 minutes and get the color of a 1mill layer.It just doesnt add up.Are you running the 2xx at the same volts as 6xx?I have found 2xx runs 2 volts lower than 6xxx.
anyway,All the shadowing I ever had was resolved by a dip in acid.
