Thread: SPRAY BOOTH
  #9 (permalink)
Old 12-04-2003, 04:28 AM
drfjr1976 drfjr1976 is offline
drfjr1976
I can't think of what it is called, it's on the tip of my tongue. I think it was called something like Thermax insulation boards.
No, it's a 4'x8' sheet about a 1/2 inch thick, has a reflective layer on one side and a black layer on the other side. You should be able to find it at just about any Home depot or Lowes.
I just built a frame like you would for any wall and put these sheets on with reflective side facing in of the 8'x8' booth. The reflective foil layer does a great job of lighting up the booth and I have it all grounded together. Majority of all the overspray sticks to the walls and makes it pretty easy to clean up.
