01-14-2009, 12:12 PM
Re: 3 2000W in a 4x4x6?
Originally Posted by newchapter
couple of questions. Is 11100 enough on elements? A lot depends on the oven construction but you should get to temp within 20 min or so.
What size wire do I need coming from my elements? If you are referring to hi-temp wire like the 842 degree MG wire McMaster Carr sells then the 20 ga would be sufficient. Once outside the oven I would use a 12 ga stranded wire. You previously referenced different sized elements. To be certain you need to list their actual size.
Were is the best place to put my vent?(1" with elbow) I'm not sure it's the 'best' place, but I placed mine about 4" from the top of the oven in the side wall.
My elements are, against the wall facing up. I have one on the back wall and 1 on each side. Were is the best place to put a fan? Im getting this one for now. Motors > HVAC Motors > 3.3 Inch Diameter Motors > Motor,1/100 HP,3.3 In : Grainger Industrial Supply
See above comments
