  #16 (permalink)
Old 01-15-2009, 09:14 AM
newchapter newchapter is offline
newchapter is on a distinguished road
Default Re: 3 2000W in a 4x4x6?
good point. I have thought about this way too much. For now I may not even go with the small fan. You got 400+ degrees going in that motor, how long will it last? I plan to go that route, and when I do I would want to get a better fan than that one
Originally Posted by CarWiz View Post
Your reference is not a fan. It's just the motor. Good up to 100 Degrees with class B insulation. It also needs air-over cooling. Not particularly suited for an oven but I guess it could be mounted remotely with an isolated shaft and fan. What may be easier is to get a high temperature blower designed to handle high heat. The motor is outside of the hot air path.
Enter "high temp blower" in Grainger's search field and you'll get the type needed. There's a 82cfm blower for just over $79 here:
HVACR > Blowers > Small Centrifugal Blowers > Blower,82 CFM,2300 : Grainger Industrial Supply
