  #16 (permalink)
Old 12-12-2003, 09:46 PM
neilfj neilfj is offline
neilfj
potsked;
To answer your question, yes, it is possible to agitate the parts rather than the solution, if you're careful.
Unless you have something to control the amount of movement, you run the risk of splashing the electrolyte and even creating an acid mist, which we are trying to eliminate. The other risk is that the constant and rapid movement required may also loosen your electrical connection.
