It's being used in office furniture,cabinets(including kitchen), even seen MDF games like gumball dispensors and pinball machines useing it. You must use a very high quality MDF and the biggest problem is dealing with the internal moisture. Definately a better product for UV cure powders,they are short bake times and the core temp never gets high enough to cause outgassing.If you hit the right temp on preheat the moisture comes to the surface and you can scip the conductive spray step and use the moisture as your conductive point of attraction.
Sorry kinda got of the original topic.
