Old 12-13-2003, 02:32 PM
mudwhump mudwhump is offline
mudwhump
Default Anodizing temperature
Hello,
I received my LCD anodizing kit recently, and of course I'm anxious to set it up and start anodizing parts. In the manual, it states that the ambient temp should be in the 60-75F range when anodizing. What is the affect if the temp is lower? Right now in my area the temp is usually in the 50's during the day and 40's at night. Is it possible to use one of the 110 deg. heaters to heat the anodizing tank, or will the acid destroy the heater? Is the other option to keep the acid tank in the house to warm up until ready to use? Don't know if the wife will tolerate a (even covered) bucket of acid in the house. Thanks for any info you can provide.
Tim
