Old 12-13-2003, 03:43 PM
tomg552001 tomg552001 is offline
tomg552001
Send a message via AIM to tomg552001
Welcome to the forum. If i were you, i would pickup atleast the 1/2 or 1hp buffer. The more power (more amps specifically) the more you can "lay" into the buffer which essentially gives you faster polishing times. I have tried clear coating polishing with powder coat, and it is not very desirable. it dulls the polish quite a bit, and when you need to touch it up, it creates a problem. You'd need to strip the powder than repolish. Your best bet is a sealer such as zoops. As far as loading the wheel, i think it means to apply the compound to the wheel itself, and not onto the part instead. WIith black i use a little bit of compound often, and the brown/white i use more compound less often. The dust will get everywhere. Make sure you wear a mask, clothes you dont care about, and prepare for a dirty ceiling, floor, body, everything in the area. Good luck!
