proper cleaning
whatever base your plating too dosent really matter except for maybe potmetal. what has improved my copper and nickel plating by far is proper cleaning of the base without a doubt. i use electrocleaner in a stainless steel stock pot with the stock pot being the anode and this way i can clean each item i plate 360 degrees all the way around instead of maybe an anode in the front and back or whatever. since i changed to doing this i never have falied a water breat test ever. have i had bad results in the plating tank?? i sure have---but not that many ----and the ones i have had can be traced back to usually to much voltage or amperage while plating, so dont blame a new batch of plating solution, my opinion would be to look at proper prep and cleaning.
bill
