Old 03-29-2009, 01:31 AM
NOL4154's Avatar
NOL4154 NOL4154 is offline
NOL4154 is on a distinguished road
Thumbs up Re: Copper Contamination in Nickel Solution
Hello,
Solution simple, dumb plate using a corriagted (wwww---) steel panel low current and before taking out panel increase to high current to seal contaimation. The corrigated steel panel gives you low, mid and high current density areas. Try not to use copper wire maybe Ti wire.
Good Luck,
Nol4154
I've used the CopyKad kit for over a year with great results. Recently a friend gave me a gallon of NiCl strike solution, unused. I ordered two nickel plates from Caswell and a new 2 gal bucket. I have a variable voltage 300ma supply set to 4 volts which should be a good test load for a small bolt or bracket. Two things went wrong:
1. I used a copper wire to hang the steel piece in the bath.
2. I reversed the polarity by mistake (for about 30 seconds). <-BAD
Copper plated onto my anodes! Now after doing about 10 cycles with the correct setup (polarity right and steel wire hangers), all the copper is visibly off the anodes, but everything I pull out of the bath is completely copper plated.
Can I get the copper out of the Nickel bath or is it ruined? I think the nickel anodes are ok, but the bath might not be. Thanks.
- Mark
