Old 12-14-2003, 12:28 PM
non-stick non-stick is offline
non-stick
you guys are aware of all this stuff,right? : http://www.caswellplating.com/permatex/index.html
totally amazes me when I take a cruise around this site as to how many things I can use as a car guy. Plastic cleaner for the door panels and such, engine degreasers, weatherstrip adhesives (check the stripping around your trunk seal. Chances are if it's an older car like mine, it could be re-worked so it doesn't slip and give you cause to replace that trunk floor in the future!). I've used permatex products for years and have always had good luck with them. Always picking up something while buying a larger part at the store. This just happens to be a good "one stop shop" for everything in the line. sweeeeeet.
Anyways... if ya knew about it all, it's old news. If you just "re-discovered" it all.... even better. Of course.... if you didn't know about any of this and can use it, more power to you in the time of year when we're forever " doing the winter project" thing with the cars.... Russ
