Dale,
Thank you VERY much! Your information helps me greatly.
I have trouble seeing where I would do more than one or two batches at a run. I do custom gun refinishing and usually don't do too many at a time so I can give a fast turnaround for the customer. I also do manganese phosphating (also will be my undercoat for powdercoating) and only fire up the tank once every couple weeks.
Would you recommend 2-3 inches of insulation space or more? I am planning on about 15-20 inches for the depth and width and 36-48 inches for the heighth. I plan on using a heating element from a old oven to heat the unit.
Would you recommend a light inside or is double pane window sufficient for letting in light to see the flow out?
Thanks,
Darin
