sounds great scott. so outgassing is basically just cooking whatever i powdercoat before i powder coat, doing it around 40 degress higher then w/e the temp is supposed to be
is it bad to powder coat a hot piece of metal? or should it be cool? and, do i need to make smooth object porus with sand paper, for powder coating
advised, i bought a welder 2 days ago, my welds blow
I AM, buying 1/2 inch sheet metal, or 1/4 do insulate the inside, leaving a inch space less then what you see
am i going in the right direction? critisize, or however you spell it hehe
