will be using the other door on the bottom if it fits, or ill extend the one on there
and the pole across is where ill be hanging ****
the welding is slowly getting easier
and the swivels. hold the door,so i say im doing a decent job
the parts with the poles, ill be welding thicker sheet metal, so it will retain heat, an leave 1 inch space between the sheetmtal, and the inside thicker sheet metal
http://www.eastwoodco.com/shopping/p...ProductID=5572
buying that kit, saturday. is that alright?
