there's an insulation out on the market that's your standard "fiberglass" type but it's in a sealed bag. You can get it at home depot. I'd also imaging you can get the spray on adhesive there as well. Can't remember the name of the insulation but I'd know it if I heard it. Meant for the "home installer" who doesn't like to handle 'glass primarily. White bag with green lettering is all I can remember. There's also a product out on the market (but it's not very thick) that's called "bug barrier". It's a flat board type of foam insulation that has a peel and stick backing to it used in new home construction instead of the standard Tyvek house wrapping. I'd imagine that would help in the flat spots a bit. I'd also do a search on the 'net for a company called Sealed Air corporation. They make that two part foam insulation that you talk about but they use it to fill those poly bags you see in shipping all the time (the kind that conform around parts). They'd be able to sell you the product. The company is located somewhere along Rt 80 in NJ (your area I believe). Of course..... I'd throw away the spray gun after using that stuff. VERY messy!
