Old 12-22-2003, 05:11 PM
Sid03 Sid03 is offline
Sid03
Default Input needed by some of the inhouse pro's.....
Hey guys, i'm trying to get some input as to a couple problems I have been having. I'm using the LCD method, a battery charger controlled by light dimmer switch, and all caswell products/kit. As far as I know, everything is set up as per LCD ano instructions.
First off, my red dye is getting pink and no deeper. All other dyes seem to be fine, but red will not work. Is there a trick to red, or did I possibly get some weak dye, or did it possibly get contaminated(if so, how)?
Next I was wondering some things. Will leaving the parts in the de-smut tank for longer periods of time have a negative effect on the whole operation? The desmut seems to remove some grime much better then the degreaser does, such as buffing compound, but I noticed that some parts that were in the desmut tank longer failed the water break test. Do you guys hand remove any buffing compound or let it for the chemicals? I know that the compound residue can be tiresome to remove and was simply looking for an easier method.
I also had some weird issues with ending up with a chalky residue. Out of 5 parts in one batch, 2 parts came out like this but the others were fine. These 2 parts were the same type of part whereas the other 3 were different shapes and possibly a different series of alum. The finish on them was cloudy/chalky with a couple spots that looked ok. The chalky areas could be somewhat scratched/rubbed away leaving a powery residue on your fingers which was the same color as the dye in that area.
I am wondering if it is ok to anodize different series of aluminum in the same batch. I would also like to know if when using the ano stripper, if there is suppose to be a black residue on the part afterwards, or if that means it was left in too long? I have had it go both ways with the stripper.
I appreciate any input to my ramblings. I have been reading these forums for awhile now and after coming up with some random problems decided to see what advise the forum guys have to offer. Thanks in advance!
