Old 12-25-2003, 02:13 PM
Stytooner Stytooner is offline
Stytooner
Default New powder coater. Hi.
Hi and Merry Christmas to all. I have just purchased a powder coating kit and some primer and powders. I have a few questions.
I make aftermarket table saw parts out of aluminum. I was looking into anodizing these parts first. This is how I located this site. Great site, BTW.
I started butting a brushed finish on these parts, then I progressed into a polished mirror finish. Each technique leaves raw aluminum and gets fingerprinted and scratched easily. I just wasn't satisfied with this.
I looked into anodizing and it didn't look as if it was going to save any time. I would still need to brush or polish the parts first.
After more research, I decided that powder coating is easier and more versatile of a technique.
Questions. Will the manual come with tips and such describing how you get the parts from the spray booths to the oven? How to handle the parts? How to remove parts from the oven incase I want to fire multiple items without letting the oven cool?
I have a compressor but it doesn't have an actual regulator on it. It will kind of regulate down to maybe 40 psi for a nail gun or something, just not very acurate. I have a tankless compressor too that could be used for an airbrush. Would something like this operate the gun? Do you have any links for a specific regulator that you have used for this process?
I make a part that rides behind a saw blade. Its called a splitter or riving knife. It is cut from flat sheet aluminum. I want to powder coat this also. Since it is mainly the upper 3/4 that would need coating, could I cure the part with it clamped vertically in an oven without the coating running down? I would expect a little flow, but it wouldn't all run off, would it?
Has anyone had any luck powder coating bright finish aluminum tread plate?
I think this is enough for now. I will try to post a pic of what I am talking about. Thanks in advance for your input.
Lee
