Re: Which gun to buy
I Agree it does look like a bad ground, but its still a 22 gauge wire thats firmly attached to the bare metal hole. Should I really need a large half inch by half inch square area to properly ground it.
Ive tested my power outlet with a ground fault tool and they ARE grounded. Did that when I was trying to do the same with my chicago gun.
Ive lowered kv to 15-25kv (<1/4)as stated on the gun. Shooting from from 5-8 inches, pressure tried between 5 and 12 psi.
I think Ill try with a OVERKILL ground. Like clip right on bare metal, shooting first coat, then die grinding to bare metal for second coat
