I just watched a video of the same gun doing a second coat, mine does not work as good with the exact same settings. It's like their 2nd coat goes on as easy as first coat, just with lower voltage.
Probably something wrong with my ground. My budget ground fault detector said its ok, but it does not give a value. I'll have to find an electrician with the proper equipment to read ground resistance, should be under 25 ohms, under 5ohms being perfect. I work with microcontrollers, I dont have any power diagnostic equipment such as these. Might have ground , but a high resistance one.
Im starting to get ****ed...
