Re: CopyCAD/Zinc Water Marks & Sealer?
Lester,
Thanks for the reply. I was beginning to wonder if anyone was out there. I have seen great results with this kit and I refuse to give up on getting it to work.
I don't think increasing my rinse time will hurt anything, I will give that a try. Do you leave the part hanging while rinsing, or do you wear gloves and actually handle the part while rinsing in the tap water?
I will also do a part tonight with less plating time to see if that helps with my rapid oxidization.
Also, are you coating or chromating the part after plating?
