Re: Calipers: Do you request a rebuild kit prior to PCing?
I also asked my self this question and all parts that are to be powder coated by me must be ready to go in the oven as is. All parts must be disassembled the the owner or a professional before it gets to me. And I will let each person know that I am not liable for any damages to parts after they are cured. I will do a check of each part so make sure I don't see any visible items that will or can be harmed or melt in the curing process and if I see something I will notify the sender. If the sender agrees to let me take the item that can be damaged out I will not re-install it but I will send it back along with the part after it is powder coated. If the sender tells me I cant take it apart I will return the item to the sender as is.
Don't take anything apart unless you have the persons consent and you make sure they understand you are not liable for any damages and you get that on paper. Its in your best interest to make a weaver for each person to agree and sign. Will save you a lot in the long run.
