You're using 10 inch wheels on a 2 amp motor? Yes, it will spin them, but it wont have ANY power. As as soon as you attempt to put any pressure it will bog the grinder down. Being able to "lay into" the buffer is what gives you speed in polishing and from what i have experienced, much better results.
