Old 12-31-2003, 05:25 AM
skot123 skot123 is offline
skot123
Default Cure method for an apartment dweller
I’ve read through an awful lot of the posts on the website and my question looks to be one that I haven’t seen addressed yet. It “may” be better suited for another forum, but I was hoping to get some advice.
(Generic information)
I would like to make customer powder coated computer cases facades. For the sake of simplicity, let’s use just the front piece. It will basically be a 10” x 18” x 1” tray.
(Problem)
I live in an apartment; I have a detached garage (WAY too far for an extension cord). In my garage, I have a single light bulb (presently running 100W bulb) and I have a single 110 outlet (presently my garage door opener, and whatever else I have plugged in at the moment.) I know from experience that I can run a miter saw, drill press, (small) ceramic heater, or halogen lights at the same time… however… I see some dimming of the main overhead light when they are turned on.
So the question is this…how can I cure in my garage without popping a breaker and killing power for all the garages (all of which have electric openers…which would generally be considered a problem)?
First thought was a toaster oven, however, desired size seems to exclude.
Next I thought about picking up a used 110 oven, but I have NO idea how much power they draw or even if I have enough juice to run them.
I am playing with the idea of the Prod M1500 for $188.50 but that is only because I am guestamating that is approx equal to the load from the miter saw or the halogen light.
I’ve seen propane based curing systems on another site, but I keep reading that you CAN use an awful lot of things to cure, you just compromise safety. Personally, I have no desire to experience a small explosion in a garage.
(Or GASP… do I need to relegate myself to the idea that I will need to find someone else to PC for me for a few years until I own a home.)
Thank you for any advice or input you can provide.
Scott G
