Old 01-05-2004, 08:00 AM
dsacco1013 dsacco1013 is offline
dsacco1013
Default What's wrong here......
Let me start off that I know I have a good ground (I think) . I got an oven and the results are 10 times better however, I have the air pressure between 10 to 15 psi. The part has been sand blasted and wiped clean with thinner. The problem is I am not sure if there is enough juice going through the gun, as for if I am any further than 6 inches away about 90% of the powder goes past the part. I understand that there is going to be some blow by but if I would hold the gun 18 to 24 inches away I would get better results from a can of spray paint if I dropped it within six foot of the part from a 10 story building .
Should I "feel" a bit of a charge if I held the part with the ground attached and sprayed it?
Also I think that 2-4 inches away is a bit close to get good results, Don't you?
Thanks, Dave
