Pictures of process and equipment
Sometimes a picture is worth 1,000 words. Quite often we come across the old " how did you do that" type of scenario. This is where you can post your photo's of techniques, solutions to equipment woes and the like. Of course.... discuss the results and such within the threads to be nice to the dial-up users, please. *JUST* the pictures and maybe a short description of what we're looking at would be more than helpful. If you have pictures of your finished parts using Caswell products, the Album is always looked at by all here.
Just so we can generate some ideas for this thread... these are things (but not limited to only these ideas) that would be helpful here.....
Coating technique (standard and "fade" pictures before cure)
Racking solutions (how do you hang a part for coating or place it in the oven for curing?)
Blasting room solutions ( care to show off your abilities on how to build a blasting solution?)
Coating booth solutions ( what does yours look like and what did you make it out of? )
Compressor issues ( did you install one with an aftercooler or figure out some neat way to keep that air dry?)
Oven issues ( did you build one on your own and care to share the results? Maybe you even have a killer IR set-up and would like to show how it's used correctly while in process?)
Again.... just the pictures only, people. All discussions to be held about photo's in the threads as it gets kinda tough for the dial-up people to keep searching through everything,k? Thanks!
