Re: Splash masking questions
if you masked first, then tried to dye once the mask is removed then thats where it goes wrong. you have to think in reverse order. you can only add mask throughout the proccess until you seal.
so for example: if you want your part black with purple splashes, you ano, then dye purple, mask, bleach, acid dip, bi-carb dip, then into the black. seal, remove mask then seal some more.
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools. " - Douglas Adams The Darkside bdk Race Engineering
