bubbled as in outgassing (looks like tiny volcanic craters all over the place) or bubbled as in there was anodize or something else under it that lifted from the metal under your coating? Be careful you don't have solvent popping happening there. It looks like outgassing a lot. It happens when you've cleaned the part to be blasted but there's still solvent left in the pores. When the part is heated, the solvent "pops" out because it's changing from a liquid to a gas (again, this is why it appears to look very much like outgassing.... because basically it is) and escapes the pores. Go to the tips and tricks section to read up about outgassing and how to overcome it if this is what is happening to you. Maybe some more details as to what is happening, type of coating you're using, etc would help. Thanks..... Russ
