Old 01-07-2004, 05:35 PM
tomg552001 tomg552001 is offline
tomg552001
Send a message via AIM to tomg552001
I suggest reading the buff manual. It basically layouts the proper way to polish. The most important thing in my mind is to do 75 percent of the work with the sisal wheel and black emory before moving into brown. Also, MAKE SURE you use the white. The white colors the part really well and helps remove haze and give it a chrome like shine. You should be using sisal with black, brown with spiral sewn, and white with a loose or canton flannel. Also, inbetween compounds make sure to clean the apart to remove excess compounds. Read the buff manual, give polishing another shot than report back and we'll see what else we can help you with.
