Old 01-07-2004, 05:59 PM
kenykirschstein kenykirschstein is offline
kenykirschstein
I did read the manual and have the general concept.
What is the best way to apply the compound when you are using a hand buffer. The manual says to put it on before the piece, if you have a frame the only way you can do that is to run the pad perpendicular to the piece which isn't what I think you want to do. Also it seems a little unsafe to run the buffer, hold the compound and try to apply the compound. Am I missing something here? The one thing I didn't do was clean the metal between the black and red compound. Both buffing pads turned gray pretty fast from the metal residue. What is best way to clean between buffing compounds. Like I stated the issue really isn't the polish but the haze and black grit in the pores of the metal. The manual hasn't stated anything different than what I already did except for what I stated. I'm sure this is a common problem and must be attributed to something obvious.
