If you have pits in the metal where the black spots are getting stored chances are you need to sand more. scotch brite is not needed, just wet sand to a 400 thouroughly and pick up some greaseless compounds. Also, try using the white, it will help with the haze and use a brake cleaner etc inbetween compounds. Most importantly, make sure to use the proper polishing motions, with to color, against the wheel to cut. What type of metal are you trying to polish? Got any pics? Pics help a lot in troubleshooting whats going wrong.
