Old 01-07-2004, 09:14 PM
Good job Mudwhump. You did everything right. And for once someone provided enough information so I could see what is going on.
The value you reached for PAR is higher than mine. If you're happy with the results that counts the most. I would recommend you get your electrolyte temperature up a bit, and Id be a suspicious about how good you electrical connection is. Both can cause a higher PAR value, and affect the time to PAR.
