Old 01-08-2004, 01:35 AM
ldangelo ldangelo is offline
ldangelo
Default Best solution for anodized "look"
Hello All,
I am looking to finish a motor in a combination of anodized blue and red finishes. I am looking for the best solution for this application.
I see my options as follows:
Powder coating (translucents)
VHT Paints
Silvachrome
Are there other solutions I should consider? Which of these solutions will produce the best results? Which will be easiest?
I have purchased a powder coating system from caswell (with the appropriate powders). Here is what I did:
1) Sand blasted the parts (with black oxide)
2) Cleaned the parts with acetone
3) Heated part to 400 degrees (don't ever forget this step... I found out the hard way!)
4) Cooled part
5) Applied chrome powder (which looked great BTW)
6) Cured
7) Applied translucent powder
Cured
The results where pretty good. However it is difficult to get the thickness of the translucent consistent. Powder will be thicker in recesses and or corners. The different thicknesses show up as different shades of blue for example.
Any ideas on what could be going wrong?
Should I continue trouble shooting the powder coating? To date I have tried to coat the same part 3 times... It is still not perfect. Stripping off the powder is a real PITA!
Any addvice would be appreciated.
Thanks in advance,
-LeoD
BTW) Great website!
