  #12 (permalink)
Old 01-09-2004, 09:23 PM
customandsound
Guest
Posts: n/a
Originally Posted by m3the01
Do i just put it on the valve cover then start sanding? How much>? Also do i use the kerosene when i using the black polish on the sisal wheel? Or only when sanding? Start at lower grit then work my way up right? Once it velvety start the polishing? When to switch compounds, when she's blinging?
Also can i use a dremel with the little sand paper disks/rubber wheel with sanding pad or only a block?
How do you sand those hard to get area's?
thanks,
Steven
when you sand it then buff it you shold get some thing like this
but i got brushed alum. top .... it is my best yet
