You CAN clean wheels from greaseless but i dont suggest it and here is why. Eventually they will become cross contaminated and different grits will act differently. Also, it wares the wheel much faster. If you use one grit for one wheel, the wheels will last forever since you wint need to rake, simply reapply. Also, with the killer price on 4 inch wheels, its not worth your time to use one wheel for all the compounds. Same with felt bobs....if used right they should last a very long time so keeping things singular is to your advantage. Good luck!
